Cooling Fans Out
Old Jun 12, 2005 | 04:46 PM
Spoolin's Avatar
Car: Convertible TA
Engine: 5. Slow
Cooling Fans Out
Hi Guys,
I have a 1992 vert. Both of my fans are not working. Here is what I have done so far. I have changed both relays and tested them before installiing. I checked the plugs for ignition with the key and i get 12v. checked for the ground from the sensor and i get it at 230 degrees. I even straight wired both fans at the plug and they both come on. What I am not getting is the constant 12v hot from the big gauge orange wires at the plug. I checked the fan fuse in the fuse box and the fuse is good. Should I assume that the constant wiring is shorted and make my own up?Or is there another fuse or link involved in this circuit that could be bad. Any light on this problem is greatly appreciated
Old Jun 12, 2005 | 08:26 PM
Spoolin's Avatar
Car: Convertible TA
Engine: 5. Slow
Found it. Fusible at the battery fried.
Old Jun 12, 2005 | 08:41 PM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
Got photos of the relay and link? I'm a bit of a novice on the TPI but have had my car for a number of years...but the cost of mechanic attention for the number of issues I have has left me to try more on my own. Getting a GM manual has been daunting as I own an 89 that has literature in demand.
I did spot a relay on the pass. side up near the radiator, I think
I've been told NAPA has two avail for mine, one at $20, the other at $50, and no refunds so I need to get the right one up front
Bill
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
