Heater Core Hose Valve Thingy
Old Jun 15, 2005 | 07:28 PM
TWICEtheRICE's Avatar
Car: 91' Pontiac Firebird
Engine: 388 ci Small block CHEVY (4.060x3.75), Dart Iron Eagle Platinum 200cc, Performer intake, 454 TBI, Long Tubes, True Dual 3" GPs
Transmission: 700R4, B&M, Governer Recal, 20,000 GVW cooler
What the heck is that heater core hose vacuum valve for?
Do you need it? Can you just hook the hoses straight from the intake to the heater core to the radiator without any problems?
Old Jun 15, 2005 | 07:47 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
The one on the passenger's side valve cover with three (I think) hoses and a vacuum line coming out of it? I believe that's for the heater control -- reroutes hot coolant into the heater core on demand from the heater controls @ the dash.
Old Jun 15, 2005 | 09:19 PM
Oh wow, they must have had some space issues with the HVAC in the dash.
SO basically you will have perma heat if you bypass that valve?
Old Jun 16, 2005 | 07:46 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
It will be ok of you bypass it.
I don't have A/C in my car so I can't tell you if it really heats up the car or not, but I believe my 86 Trans Am didn't have the bypass valve and that was fine.
I broke the one on my Formula when I was doing the TB bybass, so I just bypassed the bypass valve.
makes for a cleaner engine bay as well.
Old Jun 16, 2005 | 12:13 PM
Now that I think about it, if you don't have the blower fan ON, it will obviously not push hot air into the cabin.
Old Jun 16, 2005 | 12:16 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Now that I've removed the AIR tubes, that valve is bouncing all over the engine while driving. hehehe
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
355tpipickup
Sep 13, 2015 11:35 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
