Hot all the time....YES I used the search button...
Old Jul 13, 2005 | 11:23 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
OK I searched for the solution for this with no luck. Very short problem.
The car runs about 240 deg. all the time..... fast, slow ... doesn't matter. It does take a short time to get up there and at night when its cool it will drop down to about 220. Would a new thermostat fix this? There is plenty of fluid and no air flow problems. Fan also turns on fine.
Old Jul 14, 2005 | 01:18 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
When the car heats up touch the radiator. If its warm then the coolant is flowing through it so the thermostat and water pump are working. When the thermostat opens is another question though.
Old Jul 20, 2005 | 11:46 AM
Parrydise7's Avatar
Is a hose collapsing?
Old Jul 20, 2005 | 08:01 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
is the car really running that hot?does it ping and stutter when it is that hot?if it doesnt the problem may be in your temp sensor...if not sure about thermostat that would be the easiest thing to try first...4 or 5 bucks and about 10 minutes with a break to clean the gasket off...if you change thermostat make sure you put it in under the gasket(did it wrong my first time and it sucked) and dont cake on gasket sealer the boys at autozone like to push sealer...i never use sealer on a thermostat.and it never leaks.if you do use it use one drop and spread it with your finger very thin...hope this helps...
Old Jul 21, 2005 | 10:27 AM
crrllmich's Avatar
Engine: L03, LS1
Ok just so that if anyone else has the same problem.
To fix my problem all I did is drain the radiator, flush the system with water, replaced the thermostat and gasket, and put new fluid in. Problem solved runs under 200 even on days of 105 temp. here.
Old Aug 1, 2005 | 12:48 PM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
is your airdam attached properly?
Bubbajones_ya
Jul 6, 2024 08:32 PM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
sahlomonic
Sep 20, 2015 07:15 PM
BOOT77
Sep 16, 2015 08:37 PM
