a/c not working
Old Jul 19, 2005 | 03:14 PM
HOSS's Avatar
Car: 86 Z28
a/c not working
Hello I am new to the boards I have a question about the a/c let me start by saying I have found plenty of very helpful info and I do use the search feature long story short the car is 86 z28 lg4 v-8 with electric cooling fan but I have the cooling fan on a painless wiring set up so it was not running while it was charging the system,took 11/2 15oz cans r134 then the compressor quit running at the time I had the switch jumped out and thought I was on my way to cool and refreshing a/c but now I cant get the compressor to kick over at all I have searched and looked at the diagrams for the a/c system but now I’m stumped and would appreciate any suggestions thanks in advance,buring up in joisy
Old Jul 24, 2005 | 10:32 AM
Vader's Avatar
Check the overpressure switch for the compressor. R134 operates at significantly higher pressures than the original R12, and your current level of charge could present more pressure than the system was designed to handle.
Of course, you're NOT mixing R134 over R12, correct?
Old Jul 26, 2005 | 09:54 AM
HOSS's Avatar
Car: 86 Z28
thanks for the reply no not mixing, unit was already converted before i got the car im not sure how to test the over pressure switch though.
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
lakeffect2
Aug 23, 2015 08:44 AM
BikeFarm
Aug 11, 2015 11:35 PM
