over heating
Old Jul 21, 2005 | 08:00 AM
Fastcar92's Avatar
Car: 91 RS Camaro
Transmission: 5 Speed
Axle/Gears: 3:08
over heating
I have A 92 rs camaro 305 and have the same problem, the car runs hot. probly because I live right now where the temp is 105 to 112. would A bigger raditor and a 180 therm. I have a 195 in right now.
Old Jul 24, 2005 | 09:28 AM
Vader's Avatar
the car runs hot
Can you quantify the term "hot" so that we can understand your expectations? To some, 190° is "hot" while others don't consider the coolant "hot" until it reaches about 235°F.
Old Jul 25, 2005 | 08:54 AM
Fastcar92's Avatar
Car: 91 RS Camaro
Axle/Gears: 3:08
over heating
well how about over 220 and 230 is that hot? Would it be better with a 180 therastat?
Old Jul 25, 2005 | 03:04 PM
frankul2003's Avatar
Car: 86 camaro z28
Transmission: 5 speed manual
Axle/Gears: 3.73 limited slip
overheating
hi i have a supercharged 86 z28 iroc camaro and im having problems with my car overheating... i put double fans new belts 160 thermostat and still it run really hot.. 220-260 mostly... i try to keep the supercharger out of use but it still runs hot .. any help would be great
Old Jul 26, 2005 | 07:53 AM
Fastcar92's Avatar
Car: 91 RS Camaro
Axle/Gears: 3:08
over heating
I was looking for a little help in the over heating or getting to hot issue, but maybe I'll try double fans
Old Jul 26, 2005 | 09:40 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Expanding on what Vader was getting at, at what time during engine operation does it get hot? Is it only initially (before the thermostat opens up for the first time)? Is it constantly? Stop and go? What?
Old Jul 27, 2005 | 11:21 AM
Fastcar92's Avatar
Car: 91 RS Camaro
Axle/Gears: 3:08
over heating
yes during stop and go. I have a 195 therm. would it be better off with a 180?
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
