Electric water pump pictures.
Old Jul 24, 2005 | 05:02 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
does anyone have an electric water pump on a sbc so i can see what it looks like . Im gonna put an elctric water pump on and then ill only have an alternator and ps pump to drive . Also id like to see pics of a remote electric water pump , i see them in jegs but ive never seen what one looks like installed.
Old Jul 24, 2005 | 10:40 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I've been running this Proform for the now 4th year, no problems overheating, ever, since installation.
Alot of buddies run the Moroso belt drive electric water pump that uses a wipe motor and external bracket that mounts to the existing water pump bolts and just uses a small cog pulley system to drive it. Too many little issues with them to ever sell me to buy one, espeically after 4 years and no troubles with this one.
Old Jul 26, 2005 | 02:51 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Correct me if I am wrong IHI but doesnt a standard water pump cool beter then an electric? Also 18boyds is your car a daily driver? I always thought you would run into problems with an electric water pump on a daily driven vehicle. IHI doesnt look like his car is a daily driver.
Old Jul 26, 2005 | 07:59 AM
IHI's Avatar
IHI
Its not daily driven in the aspect of driving to work, groceries...well, it's done that before, but it has/does get driven enough to qualify it as a street car.
Would I use an elelctric pump on a daily driven? Given the results of this pump/cooling system I have now and amount of time on it..yes I would. Anything electric has a life span to it, just like your electric fans, it's not if will they go bad, it's when. Same with the electric water pumps.
As far as a standard pump cooling better than an electric unit, dont know. With the proper cooling system they perform just fine, but our cars with the bottom breather design just dont cool the best as the older muscle car johnra that had air taken stright through the grill into the rad. Do some searches on this cooling board and you can see how bad this cooling issue is, mean while witht he new stuff i installed, no matter what the outside temp is, 180* is max and that's in town, hwy, or interstae driving. So which would you rahter have?
Old Jul 26, 2005 | 10:56 AM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
my car isnt a daily driver either but i do take it on some long rides. They all seem to flow about 35-37 gph . What do standard ones frow. And when i do the enw engine i plan to put a new aluminum rad and two puller fans on along with the electric pump .
Old Jul 26, 2005 | 03:34 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
the benefit i could see with going electric is that coolant is always flowing at a constant rate. mainly beneficial at lower rpms when we normally would have lower flow rates...
just my humble opinion. (i am still running a stock belt-driven)
Old Jul 26, 2005 | 03:50 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I heard somewhere when crusing at 2000 to 2200 rpms the mechanical pump flows more then the electric. This may or may not be true. I am pritty sure a mechanical out flows a electric but I am sure thats at 3000 rpms and above so I guess if your not crusing at that it wouldnt mater.
Old Jul 26, 2005 | 04:31 PM
IHI's Avatar
IHI
Yeah, think about the rpm range your car is typically running at, 3K and below with OD and interstae driving. Even in town you may spike it to 4 or 5K, but it'll be consistantly below 3500 rpm.
Old Jul 26, 2005 | 10:04 PM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
well heres another prob you just thoguht of. I have 4.10 gears with stock size tires. so im up at 3k or more almost all the time .
Old Jul 26, 2005 | 10:30 PM
IHI's Avatar
IHI
My MINIMUM rpm on the hwy with my stuff is 3K, that is usually in town/local hwy driving. Out on the interstate to keep up with traffic I'm 3600.
If your cooling system is set-up right (like mine) over cooling is the problem, install a thermostat with some by-pass hole drilled in it and you'll be golden.
When i had this pump on my 355cid with the stock radiator/cap and street drove the thing daily I would be 180* consistantly and spikes of 200* during the hot summer months that would go back to 180* when I would start moving again, that with a 160* stat installed.
Old Jul 27, 2005 | 02:58 AM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
... So you constantly are going about 80mph? Yikes... lol, then you should prolly stick with the mechanical one if that flows better at that rpm
EDIT:: I used the calculator here on thirdgen to get that... then i did the same for a 2.73 at 60mph... - said i would be going at under 1500rpm.. thats a bunch of bull****.. lol, i was usually at 1950 and getting about 24mpg hwy... - unless my tach is off, but i doubt that
Old Jul 27, 2005 | 11:50 AM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
not always goin over 3k but when im on the thruway im like 3500 and thats like 80 . i think 55 is 2400 -2600 somewhere in there.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
