over heating
Old Jul 22, 2005 | 07:11 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
over heating
i dont know if i am the only one with this problem, but i have talked to my friends and none of them have heard of this problem. i will first say that the gauges that i have is for a 305, so i dont really know the temp is, but it shouldnt matter, but a 305 was originally in it. new engine, water pump and a put in a 160 thermostat to do with the cooling, i also have a chip so my fans turn on at 160 degrees. ok this is weird, when is start going faster and hold that speed then it starts getting hotter like at 75 or 80 mph, but when i let off and either start slowing down or when i get off the interstate and come to a complete stop, it starts cooling down then. the only thing i can think of is to give my radiator a flush since its never had one and to get a new cap since its the original one too. please help if anyone has answers or suggestions or have had this problem, thanks
Old Jul 22, 2005 | 10:14 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
It sounds like the air dam might be missing. Take a look under the front bumper of your car and look right under the radiator support. You should see a large black or gray plastic "deflector". The air dam (sometimes called air deflector) just helps keep air flowing through the radiator at higher speeds.
Here's some pictures of where it should be located. This is the one on my Camaro. The Firebird air dams look a little different, but basically the same:
Old Aug 1, 2005 | 08:18 PM
whytspeeddevil's Avatar
Car: 87 iroc-z ba boom!
Engine: V8 305 ( dont be fooled) =]
Transmission: TH-700R4 beefed up
thank *** someone took the time out to put up pics to show how and were the damn air dam thing bolts up to.....i wouldnt of known that, only cause i never had a lower air dam, i dont even know if the car came stock with it, cause there was never one there.
anyway your the best dude, all i needed to see that, and now i know how and were to bolt the air dam too, i got the piece from hawks thirdgen. good stuff man!!!!!!
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
