doesn't get down to running temp...need suggestions
Old Aug 4, 2005 | 07:07 PM
eddie jr's Avatar
Well, it is an 85 2.8 FB. THe problem is that the running temp seems to be to high. Even when I am on the highway it still hovers at the middle 105C line (221F)......sometimes about a needle width below. Last year (this is the first driving it this year)it was always halfway or farther down to the next line. The problem is that nothing has changed:
THe rad, stat, water pump, heater core and heater lines are all new in the last 2 years. Coolant will only be 2 years old in September. I just finished doing the valve covers so the top end was all off but I filled the coolant back up. Timing is set right. Upper air dam is on the car (the piece below the rad) but the lower strip (that goes from wheel to wheel) is not.....but it has not been for 3 years and it always drops to proper temp, so that would not be an issue. Fan turns on and off.
Any ideas here? I really don't like how hot this thing is running. It will probably be really bad on a hot afternoon in traffic.
Old Aug 5, 2005 | 04:45 PM
eddie jr's Avatar
so no one has any ideas??
Old Aug 5, 2005 | 05:54 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
I know you just changed your stat but i would go get another one. seems like it getting stuck or you may have a air leak somewhere. Do you have any leaks?
Old Aug 5, 2005 | 11:40 PM
eddie jr's Avatar
I can't see any leaks anywhere. And the coolant doesn't seem to keep dropping.
Old Aug 5, 2005 | 11:44 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Try temporarily installing a mechanical gauge to verify that the one in the cluster is correct.
Old Aug 6, 2005 | 08:16 AM
eddie jr's Avatar
Actually, a friend just lent me an infrared thermometer gizmo so I'll try that and let ya know what I find.
92camaroJoe
Jul 29, 2023 07:57 PM
maroe624
Apr 16, 2017 08:29 AM
InfinityShade
Aug 22, 2015 08:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mizz0313
Aug 12, 2015 06:45 AM
