help temperature rising
Old Aug 5, 2005 | 03:50 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
my car has been overheating i have to be puttin water once in awhile but its leaking water into my interior on the passenger foot area. i removed the ac last year and i never had this problem but recently i took off the condenser and those appliances on the firewall that when this thing started happening. what can i do ?
Old Aug 5, 2005 | 04:48 PM
eddie jr's Avatar
Sounds like either the heater hoses are leaking where they meet the heater core at the firewall or the heater core itself is leaking. I would think the heater core is more likely due to the fact that it is inside the car on the passenger side....so coolant always ends up on the floor.
Old Aug 5, 2005 | 05:51 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Yeah i would check the heater core too
Good luck bro
Old Aug 6, 2005 | 01:21 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
so it would most likely be the heater core? if so how can i stop it from throwing water
Old Aug 6, 2005 | 02:36 PM
eddie jr's Avatar
Unfortunately replacement is the only sure way. They are not expensive. I think mine was about 30 dollars or something.
although If you don't drive in the winter you could disconnect and plug the lines and not use the heater core.
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
bjpotter
Oct 4, 2015 07:48 PM
ironbmt
Sep 27, 2015 06:00 AM
