A/C blew cold yesterday, not today!
Old Aug 10, 2005 | 09:33 PM
Riker's Avatar
Car: 1993 Corvette & 1987 T/A
Engine: LT1 - 383ci & LG4 305 Stock
Transmission: ZF6 & 700R4
I got my A/C system charged up with R-12 freon and it held 30" vacuum for over 6 hours at the shop. Worked great yesterday and blew ice cold on my drive home from work. Today on the drive home, it worked great until the last 5 minutes of a 30 minute drive. It just blew warm air. I'm clueless as to what happened.
Old Aug 18, 2005 | 12:22 AM
Riker's Avatar
Any ideas guys? Isn't there an A/C compressor cycle switch? If so, is it easy to replace and cheap?
Old Aug 18, 2005 | 12:58 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
i have a somewhat simmilar problem, but mine quit after a week, i checked all over the engine bay for leaks, None, while i was under my dash the next day, i noticed Green liquid (NOT antifreeze not watery enough) I'm guessing its the PAG oil i put in before it was charged, Per Service station recomendations. also sry for hijacking the thread, it would be intresting to see if our problems are the same
Old Aug 18, 2005 | 08:15 AM
Riker's Avatar
No green stuff under the dash. It just quit blowing cold all at once on my way home. I've disconnected the battery for a few minutes and hooked it back up per the recommendation of a mechanic down the street. He said the computer would run the A/C after I reconnected the battery and turned the A/C switch on. His thoughts were, if the freeon was low/leaked out, the compressor won't turn on, but since the battery was disconnected, it would take a bit for the computer to re-learn that.
Old Aug 19, 2005 | 09:06 AM
NoTransistors's Avatar
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
Was the orifice tube changed? It has a screen that could have clogged. This condition will shut off the compressor.
Seth
Old Aug 19, 2005 | 09:12 AM
Riker's Avatar
Last night I unplugged the low pressure switch and jumpered the wires. The compressor did not kick on. I guess I'll take the 12v test kit and start checking from the compressor back.
Old Aug 21, 2005 | 10:42 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
you could also maually check the clutch coil by running a hot wire to one terminal and a ground to the other. if the clutch coil does not click the coil is bad. if it does then perhaps the climate control switch is bad (the little brown selector switch located on top of your hvac controls).
Old Aug 21, 2005 | 01:19 PM
What you just stated shows how hard people think before they post.
He cannot simply connect the compressor with a 2-wire jumper. There is a spike supressor diode on the compressor connector wire; therefore either he needs to remove the connector 1st, or observe diode polarity-or he will cook the diode.
Seth
Old Aug 21, 2005 | 02:14 PM
Riker's Avatar
Thank you for pointing that out. I'll be taking a 12volt test kit this week and see where the power stops at, and diagnose it from there. I appreciate you watching out for me.
Old Aug 21, 2005 | 02:20 PM
Car: 1988 IROC-Z
Seth
that is obvious, but i guess people need exact details...
also there's no need to think, it's just common sense.... just not to everyone. i forget so excuse me
Old Aug 21, 2005 | 08:34 PM
demetri's Avatar
I had the same problem and fixed it by replacing the switch
Old Aug 21, 2005 | 11:49 PM
I was harsh, and apologize.
Seth
my86bird
Oct 23, 2015 12:20 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
angel2794
Sep 8, 2015 06:22 PM
IROCtometal
Sep 2, 2015 02:01 PM
