Ditch the heater core diverter?
Old Aug 16, 2005 | 10:26 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
Well something is wrong with the diverter so I took it out of the system and the temp control on the dash still makes it hot or cold. What does it really do anyway? Old SBC cars never used them did they?
Plus it makes room on the passenger side engine compartment if you remove it, which is always good.
Old Aug 16, 2005 | 05:53 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
The diverter is small, the amount of "room" you gain is minimal. I'd rather not have hot water flowing through the core at all times, I think it's a good thing.
Those things do break with age, if it's original, it's long overdue for replacement. Else, you risk losing all your coolant at the worst possible time.
Old Aug 17, 2005 | 10:37 AM
firebirdjones's Avatar
heater
Yep, the older cars also used the valve if they had factory A/C. Just never see the old cars with them anymore, most people removed them when they went bad and never bothered to replace them. I prefer mine as mentioned above, it keeps the hot coolant out of the heater core unless the control is turned to heat, it will also affect A/C performance if you remove it, so keep that in mind if you still have A/C that works, Larry.
Old Aug 17, 2005 | 12:55 PM
mdricken's Avatar
Car: 92 Camaro
Re: heater
Yeah that's what I figured. The A/C would be a little hotter. I think what I'll do is get a water valve at Menards and just open/close the heater water line when winter/summer comes along.
Old Aug 20, 2005 | 09:30 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
You can buy a brand new diverter valve from any parts store for about $20-$30.
The valve doesn't just shut off the water to the heater core. It "loops" the flow so the water goes back into the engine rather than hitting a dead end.
ndndndnd
Sep 28, 2015 08:00 AM
Formula8r89
Sep 22, 2015 04:24 PM
