Block drain
Old Aug 20, 2005 | 02:14 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Block drain
Does anyone have any pics or can tell me where the block drain plug(s) can be found ??? I can't recall really seeing it .. .and I got all the stuff around to flus the radiator .. would like to do it this weekend
Old Aug 20, 2005 | 08:41 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
No pics, but it's on the driver's side on the middle of the engine block, right above where the oil pan bolts to the block. Just like right above the oil pan, and you should see it.
Old Aug 20, 2005 | 10:01 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
There is also one on the passenger side right under the starter. If you have a fuel injected car it's where the knock sensor screws in.
Old Aug 20, 2005 | 11:27 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Alright
Awesome.. thanks guys
Old Sep 16, 2005 | 08:57 AM
michta's Avatar
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
I replace pipe plugs in block with drain petcocks. Cleaner engine swaps when the block is emptied of all coolant.
Old Sep 16, 2005 | 08:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I use petcocks too, they make it so much easier to drain the coolant.
SRKLEGIN
Oct 29, 2015 06:38 PM
skinny z
Oct 5, 2015 06:23 PM
gord327
Sep 29, 2015 10:18 PM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
