My coolant hoses need replacing and I don't know...
Old Sep 3, 2005 | 01:06 AM
Project's Avatar
Car: 85 Camaro Z28
Transmission: 700-R4
A.) I pulled them off a month ago
B.) I don't know what size hose I need (Chevy 350)
C.) I don't remember where they go exactly. As you can tell I'm a bit of a moron, but I'm trying my best here
I would like to put the fancy steel braid over them, so if you know anyone that sells a kit for 3rd gens inform me, because I am hopeless at this point.
Old Sep 3, 2005 | 01:17 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The upper and lower hoses are fitted, you have to ask for them per application.
The heater hoses (at least for me) are 3/4" and 5/8." Where they go depends a lot on what engine they are going on....i.e need more info on the engine: carb, TPI, etc
Old Sep 3, 2005 | 01:23 AM
Project's Avatar
Car: 85 Camaro Z28
It is a 71 block, was TPI but is going carb in the next month.
Stekman I'm pulling my damn hair out. I am stressing over everything that needs to be done to my ride
Old Sep 3, 2005 | 01:32 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Keep your hair on your head. I hear it does you better good up there than on your floor somewhere.
Coolant hose routing is fairly simple for carbureted cars. Assuming you are using a heater core, all you need are 4 hoses. The upper and lower radiator hoses, being form fitted, ask for them by application. The hoses to and from the heater core are 5/8" and 3/4", just ask for a couple of feet of each. I forget which size goes where, but one goes to the water pump, and the other goes to the front of the intake manifold. Just get a couple of fittings from the hardware store (you don't HAVE to, but I like new fittings where ever possible on new engines).
Old Sep 3, 2005 | 10:04 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
if the car was originally tpi, then doesn't he have a heater hose coming from the radiator going to the heater core? if this is the case then either the radiator connection will have to be plugged or he could just use it instead of going to the water pump.
Old Sep 5, 2005 | 11:15 PM
Zig's Avatar
Zig
Car: 91 Z28 with 64,000 miles
Stekman is right about the sizes. I just replaced every one of my hoses last weekend. I also had an oil cooler which adds a couple lines. between the radiator and heater core. Best thing I did was go to the NAPA website. Not because they had heater hose diagrams for most applications (except mine) but becasue they actually had all my hoses listed. To top it off, the local store had all of them in stock!
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
