Why no light on manual fan switch?
Old Sep 15, 2005 | 12:25 AM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
I was reading the sticky, and they said, don't use a toggle with a light. (I know it's just providing the fan relay with a ground)
Why is that? not enough juice?
Old Sep 17, 2005 | 03:09 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
ive heard that and im no sure. it probably as something to do with the light creating an exra load in the circuit
Old Sep 17, 2005 | 07:53 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
i'm interested as well....tried to rig up an LED to the fan switch, no luck....drove me crazy till i just decided it HAD to be that there was some reason why it wouldnt work, while the same LED on the same switch wired into the electric fuel pump it worked fine....
Any info would be greatly appreciated! would a relay be needed for this to work?
Old Sep 18, 2005 | 05:33 PM
waltersb's Avatar
I do know that the bypass for the fan relay is just a ground.
You ground the relay and it trips causing the fan to come on, I don't think there's any current in it. Just my thoughts
Old Sep 19, 2005 | 03:23 PM
jethawk's Avatar
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
maybe try hooking the ground post on the switch to a positive power source?
Old Sep 21, 2005 | 09:46 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
you could just hook the led, or light up parallel with the relay, that way when you send power tothe relay, you will be sending power to the light as well.
eightsixseven
Dec 16, 2024 01:50 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
stalkier
Aug 21, 2015 01:54 AM
TA8487
Aug 16, 2015 12:21 PM
Omega
Aug 10, 2015 12:46 PM
