Need Heater Help!!!!!
Old Sep 19, 2005 | 05:21 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
I replaced the pass side valve on my iroc, my heater works, but it will only blow out of the defrost, no matter where I set the control panel!!!! Any help would be much appreciated.
Thanks 90IROC1
Old Sep 19, 2005 | 05:58 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The HVAC control vacuum line is broken or disconnected somewhere.
https://www.thirdgen.org/techbb2/sho...hreadid=250925
Old Sep 22, 2005 | 12:00 AM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
O.K. I tore the consol out and got in to he heater control unit. there is a plastic fitting with four plastic hoses going to it for the heater vent controls. That is where the air is gushing from!!!! I pushed it on harder and it stoped leaking air from it. All the different settings worked d-frost, heat, vent. I put the flippen thing back togeather and it flippen leaks aganin and wont come off of d-frost. Any ideas on how to fix would be appricated
Thanks 90IROC1
Formula8r89
Sep 22, 2015 04:24 PM
BWilcox
Sep 20, 2015 12:19 PM
