Fan specs needed
Old Sep 15, 2005 | 05:45 PM
vwdave's Avatar
Fan specs needed
I checked google/yahoo and searched on here and didnt find the answer I need.
My car is having alot of trouble cooling at idle. I have a 3-core radiator, 2 flex-a-lite fans (210's I believe.) Still cant get the job done. I want to put a Lincoln Mark 8 fan on there. Can anyone tell me the dimensions of it?
Currently, I have 2500 shrouded CFM's and I need more. What is really pissing me off is the fact its a mostly stock L98 and without the AC on, it goes to 230*!!
TIA.
Old Sep 16, 2005 | 04:31 PM
chesterfield's Avatar
Car: Pontiac
http://www.geocities.com/smithmonte/...rkVIII_Fan.htm
don't settle for a taurus fan if this will fit. make sure it looks like the one on this page.
Old Sep 16, 2005 | 09:44 PM
vwdave's Avatar
Thanks alot. I am starting to think my headgasket/s are shot. We'll see.
Old Sep 17, 2005 | 12:53 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
That should be more than a sufficient enough system (what you have now). I run a dual pass design and only have 1600ish cfm accross it and I have to tape over the bottom portion of the radiator to prevent over-cooling.
Try pressure testing your cooling system.
Old Sep 17, 2005 | 07:35 AM
vwdave's Avatar
Now that I think about it, I can remember EXACTLY when it started. When I went from TBI to TPI.
I bought a computer from my junkyard out of a "91 L98 Camaro" Put it in and it ran like crap. Well, my employee was screwing with some adjustments and got it running ok. I later found out he cranked the timing way up and the passenger side header was glowing red. I switched the chip with a dealer unit, and since then, its ran great, but the car wont stop overheating.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
Leggman1
Aug 6, 2015 04:15 AM
