Water temp gauge
Old Sep 30, 2005 | 10:41 PM
ThUnDeR2005's Avatar
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
Water temp gauge
Hi everyone, just a quick question.
How do I get a water temp reading? When I finished the swap, I still have some gauges not hooked up. One of them is the stock water temp gauge. I don't know where it goes, as I don't see a provision for it anywhere on the radiator/waterneck/manifold.
Can someone help me out? Or would I need an aftermarket one?
Even then, where would I connect that to? lol...
Old Oct 1, 2005 | 01:05 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Factory put it in the hole in the driver side cylinder head, between the 1 and 3 holes.
Old Oct 1, 2005 | 01:07 AM
Engine: 355 TPI
Oh... does it stick out a bit?
Hmmm... odd I don't see how that connects to any wiring of sorts... maybe I gotta look it over. The block is an 80 350... possibly could be different I guess...
Old Oct 1, 2005 | 01:15 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Just a little sensor that screws into the hole in the side of the cylinder head, not the block. Simple male/female spade connector on the sensor itself.
Looks pretty much like this:
Bubbajones_ya
Jul 6, 2024 08:32 PM
tommy z-28
Oct 6, 2015 10:58 PM
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
86IROC112
Sep 11, 2015 04:04 PM
