how to wire markVIII fan into 92 TPI car?
Old Nov 4, 2005 | 12:07 PM
SatisTraction's Avatar
Ok i have a 92 TPI with dual fans and i am convderting to a lincoln markVIII fan. the lincoln fan is dual speed. can i just run the two power wires from the old relays to the low and high speed on the fan? i jsut ma not sure if you are supposed to energize BOTH sets of windings to get high speed.
any help would be great.
thanks
chris
Old Nov 21, 2005 | 04:52 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Do not do that. The way that fan wiring from the fan should work is that at one setting (low) it will recieve power to only (-) and the low wire. Then at High speed it will recieve power to only teh high and (-) wires.
You can go ahead and only connect one of the fan's wires (high speed) to the IROC's first fan lead. You will not need to wire two.
What year is the fan from by the way?
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
penguinpanda0
Aug 15, 2015 06:45 PM
L98GTA87
Aug 5, 2015 11:02 PM
