Water Pump Gaskets
Old Nov 4, 2005 | 01:03 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
Water Pump Gaskets
I am considering replacing my OEM water pump to a higher flow pump such as Edelbrock, Stewart, Weiland, etc. I have two questions. First, is there a gasket between the pump and the block where the water flows and do most of these pumps supply the gaskets? Second, I have heard some people have had to modify the air conditioning pump bracket to make the new water pump fit. Have people installed these pumps and had to modify the bracket to the left of the pump?
Old Nov 4, 2005 | 02:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yes, there's a gasket. I got mine with my gasket set.
Not sure about the AC part.
Old Nov 4, 2005 | 11:01 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
If you get the Edelbrock one, you will have no problems with your serpentine brackets. I've got an Edelbrock Victor Series reverse-rotation Long Pump, and it works great!
Old Nov 5, 2005 | 03:51 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
The Edelbrock Victor series water pump is what I am considering. Nice to know you did not have to modify GTA brackets. Did it come with the gaskets? I understand that you can get replacement bearings from Edelbrock. Is that true?
Old Nov 5, 2005 | 04:47 PM
thirdgen88's Avatar
Car: 1995 Corvette
Haven't needed to replace the bearings yet (knock on aluminum), but it comes with gaskets.. You'll want some kind of gasket sealant for them.. I use RTV blue for water pumps.
Old Nov 13, 2005 | 04:21 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Here is Edelbrock's response to my question:
Raymond, our water pumps are provided with all necessary mounting gaskets.
We actually provided a quick rebuilding service for all of our water pumps
and don't recommend them to be built by anybody but us. Turnaround is
usually within the week. As long as the vehicle is started up and not left
sitting for weeks and months, there should be no durability problems. We
appreciate your interest in our products. Thanks.
Ray Garcia
Edelbrock Corporation
Technical Sales Representative
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
