fans
Old Nov 6, 2005 | 10:42 PM
b80vette's Avatar
Car: 80vette 88iroc 74z28 79 f100
Engine: l48 lb9 l82 302
Transmission: 350 700 400 c4
fans
i can only get my fans to turn on i jump the fans at the relays so i know my fans work so it must be the relays pleas help thanks
Old Nov 7, 2005 | 11:53 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Could be. Could also be that the switch side of the relays isnt being activated. Could be a faulty coolant temp switch. Make sure that the control side of the circuit is operating properly. Do the fans turn on when you have the ac on?
Old Nov 7, 2005 | 05:50 PM
b80vette's Avatar
what wire is that and can i test that with a test light.ill turn on the ac and see if that works thanks
Old Nov 7, 2005 | 10:53 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
It's not a matter of testing a wire. At the set temperature, the fan switch grounds out the relay. Try unplugging the wire at the fan switch (passenger side cylinder head, between the 6 and 8 cylinders). The primary fan should turn on (assuming you have a dual fan setup).
The A/C circuitry controls the second fan.
Old Nov 9, 2005 | 04:56 PM
b80vette's Avatar
grouned the fan wire and the relay just clicked.let the car get up to temp and turned on the ac and nothing so it must be the relays
Old Nov 10, 2005 | 12:55 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Since the relay is clicking, don't bother replacing it so soon.
Locate the fan relay and pull the black/red (pink) wire from it. This is the wire that powers the fan once the relay is switched. Give this a 12v source and see if the fan comes on.
Old Nov 11, 2005 | 07:43 PM
b80vette's Avatar
heres the deal i can turn the fans on if i jump the blk\pnk to the brown wire but i have no power coming from the orange wire and i though that was hot at all times iv checked the grounds and there good so why no power from the orange wire
Old Nov 11, 2005 | 11:28 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
fuseable link down by the starter...
Old Nov 12, 2005 | 11:24 AM
b80vette's Avatar
my + cable runs like this one cable to the starter and one to the alt the one that gois to the alt has two fusible links one is black and one is orange no power at the orange one tha is hot all the time.do you think gm still has this cable if not were do i get it thanks
Old Nov 12, 2005 | 04:38 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I burned my fusible link up when my fan died, I just put a fuse in it's place. You can buy replacement fusible link wire from Autozone though.
Old Nov 12, 2005 | 05:54 PM
b80vette's Avatar
id like to just get a new +cable from gm ill give them a call on monday to see if they still can get it
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
