Reverse or Standard Water Pump???
Old Nov 9, 2005 | 11:43 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Im using a serp setup from an 89 305 car on my 88 camaro with a 98 model carbed 350. I bought the setup from a guy on here. I need to know what water pump I need. The pump that came with the serp appeared to be a standard rotation. Advance auto said it only called for a standard rotation. But that goes against what I think it should be. Im sure some of you guys have the same setup and can tell me. The serp belt goes over the water pump and then back down and under the crank pulley. Please help guys.
brad
Old Nov 9, 2005 | 11:50 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
A serpentine belt setup uses a reverse rotation water pump. The belt goes around the water pump the opposite direction compared to a v-belt, and hence reverse rotation. How do you know your pump is not reverse rotation? You would have to remove the cover and compare the impeller to a standard rotation one to determine it.
Old Nov 9, 2005 | 12:03 PM
3rdgenmaro's Avatar
Car: 88 IROC
We took apart the old pump and it appeared to match the standard style. one Advance store ended up giving us a reverse pump and a standard pump. Another advance store (with a guy that we know and trust) told us that which one was which. So right now we have a standard pump on the motor. I guess that is wrong then? Why would advance only have the standard pump listed? Im so confussed. To me it appeared to need a reverse flow pump as well. Since it turns opposite the crank.
The motor that is in the car had a reverse flow pump on it. Of course the people that poorly rigged it up had it turning like a standard pump.
Just to make sure it was a reverse flow what pump comes on a 98 model 5.7L? The motor came from a hertz rental truck. Anybody know?
Old Nov 9, 2005 | 12:50 PM
Lo-tec's Avatar
Yes, that is wrong. Get a replacement pump for the 89 belt setup that you are using (assuming there are no differences on your 98 block). The 98 should have been a reverse rotation pump also (no v-belts in 98).
Old Nov 9, 2005 | 01:00 PM
3rdgenmaro's Avatar
Car: 88 IROC
thanks alot. I have been lost in this. Parts stores are not good at these things. Thanks again.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
MoJoe
Sep 24, 2015 09:12 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
