Why two fan relays?
Old Nov 9, 2005 | 07:00 PM
Zokal's Avatar
Car: 1989 Firebird Formula
Engine: Chevy TPI 350
Transmission: A/T 700 R4
Why two fan relays?
I have dual electric fans and was wondering why is there two fan relays? Is one for each fan? If so, do you think it is still possible that my fans are not coming on because the relays may need replaced? I mean, two relays are not going to all of a sudden go bad at the same time, right? If it was a relay problem, one of them should still click on seeing that there is a relay for each fan right? For example, if the relay which operates the a/c controlled fan is good, it should click on when the a/c is turned on. Basically, I need to know what the purpose of two relays for the dual electric fans? Also, should I replace both relays, because the fans do not come on at all. (I checked fuses and turned on the a/c)
Old Nov 10, 2005 | 08:59 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
yes the relays for the the two fans. One fan the primary one (left) is controlled by the coolant temp sensor which sends a signal to the ecm and the ecm says "turn on. The other is controlled by the fan switch or if u turn the a/c on. The fan switch will tell that fan to come on at a higher temp then the primary one. The primary turns on at around 220 and the secondary turns on at around 240 or something.
Old Nov 10, 2005 | 09:53 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The ECM has nothing to do with fan operation on these cars. It's the fan switch and the A/C.
Old Nov 10, 2005 | 11:51 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Ah yes the ecm has something to do with fan operation. If you ever have a scaner hooked up to your car you will the ecm has a spot for the fan being off or on. Also thats why you have two coolant temp sensors. One for the gauge and one for the computer. Also loudmouth is right. the fan comes on at 220 and the second fan will come on at 240 or if the ac is on.
Old Nov 14, 2005 | 07:09 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
ECM controls the primary fan (Fan1) Fan2 is listed but I don't believe changing the on/off temp on that one will do anything,
Old Nov 14, 2005 | 07:43 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I think fan two is controled by the ac. Check the ac wiring scimatic and I am pritty sure you will find it.
Old Nov 14, 2005 | 08:55 AM
Zepher's Avatar
It's controlled by the A/C pressure switch and the the temp switch in the pass side head. those are wired in parallel.
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
