My motor + stock radiator = over heated motor????
Old Nov 27, 2005 | 08:50 PM
spedrace35's Avatar
Car: 91 camaro z28
Engine: 6.3L, heads, headers, cam,.....
Transmission: 700-R4 w/shift kit and 3-4 WOT kit
Axle/Gears: 4.11
Ok you guys this is my problem I have been building my motor for about 16 months or so, it been taking me so long because well parts are way too expensive. Anyways Ill get to the point I am hoping that my car will be running by the middle of Jan but I will be using the stock radiator. I plan to get a nice 3 core aluminum radiator probably in late March. Well do you guys think I will be ok using my stock radiator with my combo? Look at my sig for my combo, O I don’t know if this will help but I bought a Milodon high flow water pump. Thanks you guys!
Old Nov 28, 2005 | 01:26 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Assuming the rest of the cooling system is up to par, I have seen cases of a factory radiator (in good shape) cool upwards of 450 hp. And yes, the upgraded pump will help.
Old Nov 28, 2005 | 12:55 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
OK thanks a million!!
Old Dec 13, 2005 | 03:09 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
I had luck with a 500hp 400ci only when using a clutch fan and shroud. I switched to electric and it over heated so back to the clutch fan I went
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
mustangman65_79
Sep 1, 2015 03:51 PM
mustangman65_79
Aug 8, 2015 01:18 AM
