Bad thermostat?
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Bad thermostat?
Do I have a bad thermostat?
My oil temp heats up like it should. But my water gauge takes forever to increase while the engines idling.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Are you reading the stock oil PRESSURE gauge? If so then you want it up right away or you'll be buying a new engine. How long is "forever" to get up to temp? Probably take 5-10 minutes in my car.
