fan switch question
Old Dec 1, 2005 | 09:58 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
Transmission: automatic
fan switch question
I bought a fan switch from summit a while back (pn jet-60600) and went to hook it up a week ago, and noticed a problem... The sensor that was there had two wires coming from it, while the new one only has one. Can i just take out the sensor it came with and put in my stock one, our would that just send the same signal as before. Or if anyone can tell me which wire to splice it to, and what the other one is for, that would be a tremendous help. Thanks in advance!
Old Dec 1, 2005 | 10:30 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Fan switch goes in the pass cyl head between cyl 6 & 8, temp sensor goes in the intake manifold. Your old fan switch should look just like the new one.
Old Dec 2, 2005 | 11:12 AM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
crap
well thanks man, I put the dang thing in the wrong hole. Are you sure this is where it goes, cuz i dont wanna crawl under there if i dont have to!
Old Dec 2, 2005 | 11:43 AM
Lo-tec's Avatar
Yes, that is where it goes. Is it too hard to get to from the top? You're going to get a mouthful of coolant if you take the switch out from underneath.
Old Dec 2, 2005 | 07:46 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Shhhh, don't warn him .
I agree though, unless you have some crazy headers, then going from the top is the only way really.
Old Dec 2, 2005 | 11:23 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
good thing
Well guess its a good thing i didnt put any coolant in it yet then. Thanks for the info guys, solved one of the problems anyway!
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
redmaroz
Aug 16, 2015 11:40 PM
TA8487
Aug 16, 2015 12:21 PM
Fronzizzle
Aug 9, 2015 01:15 PM
