Radiator
Old Dec 25, 2005 | 11:42 PM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
Radiator
I was just wondering if the stock rad used in 4 cylinder 3rd gens is sufficient for a v8 swap?
Old Dec 26, 2005 | 03:32 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
Nope hit up advance auto
Old Dec 26, 2005 | 04:10 PM
elky74's Avatar
What about Jegs universal aluminum radiator with a flex fan?
Old Dec 27, 2005 | 07:20 PM
8UpAFord's Avatar
Car: 1988 Corvette
not sure about that, all i know is that 4 cly rad is not sufficient for a V8
good luck
Old Dec 28, 2005 | 02:19 PM
elky74's Avatar
good luck
Thanks, I guess that's all I need to know about that. Time for a new aluminum radiator!
Old Jan 10, 2006 | 03:32 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
when i get one for my 82's i am getting copper brass and putting on a stock factory solid fan, make sure i get all the air through the radiator as possible, and build a custom shroud out of aluminum, box it in good around the radiator and fan blades, least amount of gaps as possible to make all the air have to come through the radiator
keep it form overheating at lower speeds for sure then
good luck
Old Jan 10, 2006 | 03:53 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Actually, believe it or not, the radiator is the same for 4cyl and v8, but different
for a v6. Modine p/n: 951.
Old Jan 11, 2006 | 12:23 AM
elky74's Avatar
You're saying I can use my stock rad? If so, that would help save a little money on the project.
Old Jan 11, 2006 | 09:01 AM
'Shifter's Avatar
Car: 87 Z-28
According to both Modine and Visteon, both major manufacturers, they are
one and the same.
Old Jan 11, 2006 | 09:37 PM
elky74's Avatar
Thanks man.
Old Jan 12, 2006 | 09:04 AM
'Shifter's Avatar
Car: 87 Z-28
My pleasure.....
sheachopper
Jul 31, 2019 11:27 AM
lanceflame44
Sep 25, 2015 12:28 PM
