Water pouring out side of motor?
Old Dec 31, 2005 | 08:48 PM
toma's Avatar
My girlfriend has an 89 GTA Convertable with a 5.7 350 motor. Is it possible if there was only water "no antifreeze" in the engine during a hard freeze "8 degrees for 4 days" for ice to blow a head gasket? She tried to start it and the unibelt melted under the water pump. I figured it was frozen. Now that it warmed up a bit I replaced the belt but when I started to add antifreeze I saw it pouring out from the right side around the middle of the engine. Figured the freeze plug blew but its fine. I could'nt see where it was coming from so I got a 3'' telescoping mirror and it seems to be coming from the seam between the block and the head. When I pour a little water in the radiator it pours out. Could a head gasket have water pour out with no pressure on the system and with no water mixed in the oil?
Old Jan 1, 2006 | 08:29 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Yes. Being it's coming from the center location (between plugs 4&6 or 3&5) accually, your lucky! usually when the cooling system freezes, it cracks the block on the side or the lifter galley.
When water freezes in your engine it will find the weakest spot when it expands. when you get the head gaskets replaced, you need to get the heads checked for cracks and warpage.
Who ran straight water in it anyway? (shame-shame!)
Old Jan 1, 2006 | 02:07 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
i run straight water with a rust inhibitor in the summer - cools 5x better than coolant, plus the tracks get a little PO'd if ya blow any coolant out on it!
i do however do a flush in the fall and switch it back to antifreeze!
i would definately pull the intake off that motor to check for damage!
Old Jan 4, 2006 | 10:01 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
it just had to a 5.7...
Old Jan 16, 2006 | 10:59 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I had a 350 block crack abt an inch below and parallel with the head gasket. Guy at the machine shop said that was a common place for them to crack due to freezing.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
lakeffect2
Aug 23, 2015 08:44 AM
Elliswon
Aug 10, 2015 12:33 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
