82-85 belt driven fan info needed
Old Jan 9, 2006 | 01:33 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i need part numbers and size info for the cooling fans put in the 305 cars without a/c
are they clutch style or not ? i know the a/c ones probably were
part number ?
size of fanset ?
blade count ?
spacer or no spacer ?
length of bolts ?
will a fan out of other makes and models fit and work and clear ?
does anyone have a stock original LG4 car from 82 to 85 ?
this is what i would need info for/from
help please thanks
Old Jan 10, 2006 | 03:30 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
wow so no one has a stock factory 82 85 LG4 anymore ?
damn
that sucks
help ?
thanks
Old Jan 25, 2006 | 09:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
my '82 LG4 fan and water pump are sitting on the ground. I can give you any measurements you need, let me know.
I'm about to start a new thread about replacing it...
Old Feb 1, 2006 | 06:05 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
how large is fan across
is the radiator stock ?
if so then is it alum or copper
how wide from tank seam to tank seam
does radiator sit in the shroud or in front of it
thanks
Old Feb 1, 2006 | 07:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
17"
dunno. easy way to tell?
Not sure which measurement you want here.
pic
arrow to arrow is 26 3/8" +/- 1/16"
*edit* there's a broom handle in the way, that's what the left red arrow points to, I actually measured all the way to the end of the fins, just like the right side.
in shroud
That about cover it?
Old Feb 12, 2006 | 02:34 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
yeh that solves a few mysteris for me so far
i appreciate
also if anyone has pic of an original early third gen LG4 fan then please lemme see
also do they use one of those aluminum spacers ? or is it clutch driven all the third gen years ?
thanks again
Old Feb 12, 2006 | 05:31 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
From my '83 service manual it states that the majority on non-A/C vehicles have a 4 blade fan.Then some models have a 5 blade variable pitch fan.The next paragrah states that some A/C equipped vehicles have a clutch fan.Now that's about as clear as mud LOL.To complicate things more,cars with heavy duty cooling will have a 7 blade clutch fan(mine is like this and the fan is 18" across).The flex fan vehicles would have to use some type of spacer to place the fan properly in the shroud.The fan is positioned inside the shroud typically with the blades width centered(half inside and half outside).I hope this helps more than it confuses.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
