My heater aint not workin...
Old Jan 9, 2006 | 09:47 PM
Treys_IROC's Avatar
Car: '89 Camaro
Engine: Blown 5.7L TPI
Suggestions? please help, as its cold outside i would like to use my heater.
Old Jan 9, 2006 | 10:03 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
"Isn't not working"....so what's really wrong with it then?
Anyway, if the fan works at speeds as it should, just no heat, it sounds as if you have a blockage somewhere, be it either in the hose, the heater core, or a bad diverter valve.
If the fan doesnt work at all, that's your problem.
Old Jan 9, 2006 | 10:09 PM
Treys_IROC's Avatar
Car: '89 Camaro
is their a way to open the heater valve?
Old Jan 9, 2006 | 11:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Replace it. It's a cheap plastic part. Assuming it's getting vacuum...
Old Jan 10, 2006 | 03:59 PM
Treys_IROC's Avatar
Car: '89 Camaro
I checked to see if theres vacume on the line to the heater valve and there was none.
Old Jan 10, 2006 | 04:09 PM
Treys_IROC's Avatar
Car: '89 Camaro
Old Feb 1, 2006 | 08:36 PM
Meinherr49's Avatar
Car: 1988 Pontiac Formula 350TPI HARDTOP
Engine: 04- 350 Crate Motor with Crane Cam
Axle/Gears: 10 Bolt Posi 3.73:1
Try this
A Coolant Bypass .
Old Feb 1, 2006 | 10:22 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Re: Try this
He want's to use his heater, not bypass it Besides, that's for the throttle body, not the heater core.
Check for vacuum at A/C set to max. Otherwise, in a pinch, you could just straight line it and plug the diverter valve hose off where it connects to the engine.
Old Feb 2, 2006 | 06:44 AM
michta's Avatar
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
Thermostat stuck open?
Old Feb 2, 2006 | 11:22 AM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
You can bypass that thing. Just run the back of the intake to the inlet, and then the outlet directly to the radiator. I did mine like this. I have also seen many people do it this way. No heats will come in the car unless the fans on. MY
Old Feb 5, 2006 | 05:45 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
KEEP KOOL WHILE WE DIAGNOSE THE PROBLEM
</TD><CENTER><TABLE BORDER=0 CELLPADDING=0
<TD BGCOLOR=33CCCC WIDTH=0>
<FONT COLOR=YELLOW><H5><CENTER><P>You require vacuum to
open the coolant diverter valve. Trace the hose back to make sure it
is not broken or pinched. If it’s OK then check your HVAC panel
for proper switching. If you bypass it you will always have a little hot air coming into the driver's area in the summer.</H5><H3><P><CENTER>REFUSE
TO
LOSE</TD>
</CENTER></H3>
Old Feb 7, 2006 | 01:50 AM
joshwilson3's Avatar
Old Feb 7, 2006 | 05:02 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Try taking the top off the radiator and adding coolant. It works!
Old Feb 8, 2006 | 01:45 PM
Formula8r89
Sep 22, 2015 04:24 PM
BWilcox
Sep 20, 2015 12:19 PM
