wireing duel fans on 87 iroc
Old Jan 22, 2006 | 11:22 AM
dexter higgins's Avatar
Car: 87 iroc z28
Engine: 350 tuned port
Transmission: auto
i have recentley bought an 87 iroc z28. someone had straight wired the fans an had cut off the connectors to the fan as well as the ones on the wire going to the fan so im not sure which wires goes were can some one shed some light on it for me please
Old Feb 13, 2006 | 02:44 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
87 Fans
Hi,
I think I would go to a good salvage yard and find the harness
that comes down the passenger side and cut it back as far as
you can. I have one harness that splits into two for the fans
with one wire coming out for the secondary fan relay. By doing
that you also get the connectors for the fans. Then just match
up the color coding to where they cut it off.
Probably alot of years up with same setup.
Hope this helps;
Later
jaykar
Old Feb 15, 2006 | 06:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The fan pig tail part #'s are listed in the following thread:
https://www.thirdgen.org/techbb2/sho...hreadid=309711
JamesC
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
