Over heating problems
Old Jan 26, 2006 | 07:28 AM
wheelstandin87's Avatar
Car: 87, 88 and 89 Iroc-Z
Engine: 305, and 350
Transmission: 700R, and T-5
Axle/Gears: 3:23 POSI
What happens to your motor when it over heats? Does it screw it up really bad? What should i do if say the temp got up to 260 or alittle higher?
Old Jan 26, 2006 | 02:10 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
260 degrees isn't in the real danger zone although any weak parts,especially seals and gaskets will more than likely be the first to fail.Remember the factory electric fan switch doesn't close until 225-235 I think.Did you have a problem with your car overheating recently?
Old Jan 26, 2006 | 04:43 PM
yes it did and its becuase my radiator has a hole in it and the water ran out while i was on a trip and it went to 260 and i stopped and filled it but still i dont want it to be destroyed becuase of that i herd its terrible for the motor to run that hot.
Old Jan 26, 2006 | 11:33 PM
LAN_Lord's Avatar
Car: 1989 v8 305 TBI Camaro
Engine: 5.0L 305ci V8
Transmission: Stock/ TR400 or whatev
yeah, to be honest i've overheated my car once, thats only cuz I was on the way to do the water pump, it overheated a little, but i havent noticed any problems so far.....It's bad, but as long as you don't make a habit of it, you'll be fine.
Old Jan 29, 2006 | 07:40 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
LOSING HIS COOL
Originally posted by wheelstandin87
What happens to your motor when it over heats?..............
<CENTER><B>A small block chevy can take the heat. You aren't getting
damagingly hot until you have popped a hose (which leaves a
James Bond style fog behind you) . As it goes over
300° it will be difficult for it to run (sort of a
serendipitous safety feature!) . Now if you continue to run without
water in your block engine damage will occur.</B>
<P>
<TABLE BORDER=9 CELLPADDING=18
<TD BGCOLOR=black WIDTH=60><B><H3><CENTER>REFUSE
.TO
.LOSE</TABLE>
chazman
Aug 28, 2018 03:25 PM
greenyone
Sep 2, 2015 03:39 PM
mustangman65_79
Sep 1, 2015 03:51 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
chazman
Aug 22, 2015 02:01 PM
