bbc cooling
Old Feb 13, 2006 | 05:56 AM
greenmachine116's Avatar
Car: 89 iroc
Engine: 454
Transmission: th 400
bbc cooling
Im running the stock radiator and the stock daul fans the problem is when the car sits with the fans on and Idles for around10 minutes or in a slow cruise less then 10mph the tempature creeps up on 230 what can I do to cruise at 10mph and keep the tempature down the big block is mild with 8.75 to 1 compression and small cam it is a gm performance parts crate 454 rated at 425hp.
Old Feb 13, 2006 | 02:23 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
BB Radiator
Hi,
If you have checked the usual culprits, Thermostat, WP, ect,
and overheats with both fans running at idle it probably is
going to need a bigger radiator. Had a 427 L88 in a 2nd Gen,
( Different setup I know) and had to go to a four core truck Rad
for the street to keep it cooled down. But Radiators today have
gotten more efficient for thier size.
I'd say bigger Rad.
Later
jaykar
Old Feb 14, 2006 | 12:49 AM
Car: 89 iroc
Engine: 454
thats what i probaly have to do is replace the radiator I was hoping not to.
thanks
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
