AC Removal
Old Jan 28, 2006 | 06:37 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
AC Removal
Can anyone help me on this issue? I run a v-belt setup and want to clean up the engine a little bit as well as save some weight. My question is, can I remove everything up to the a/c canister and just leave that there? WIll my heat still work?
This is not my engine, but I believe this guy did what I want to do. Is there anything wrong with this setup?
Old Jan 29, 2006 | 07:07 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
LOSING HIS COOL
Originally posted by 87TPI350KID
................can I remove everything up to the a/c canister and just leave that there?.................
<CENTER><B>Yes you can 87TP, the heating path is separate.
<CENTER></B><P><CENTER>
<TABLE BORDER=9 CELLPADDING=18
<TD BGCOLOR=black WIDTH=60><B><H3><CENTER>REFUSE
.TO
.LOSE</TABLE>
Old Jan 29, 2006 | 07:54 PM
I noticed an electrial connection was plugged into this canister, will that throw any codes?
Old Jan 29, 2006 | 09:24 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
No. I believe that is the pressure switch for the system, and It shouldn't be tied into the ECM.
Old Feb 6, 2006 | 01:44 AM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
so with doing this you can still use your heater without getting a non-a/c control box? what about if you take out the canister and plug up the lines? and do you have to drain the coolant when you take out the a/c?
Old Feb 6, 2006 | 05:27 PM
NINÅ's Avatar
Transmission: 765R4
LOOSING HIS COOL
Originally posted by Trah84Z 1.
so with doing this you can still use your heater without getting a non-a/c control box?2.what about if you take out the canister and plug up the lines?3.and do you have to drain the coolant when you take out the a/c?
</TD><CENTER><TABLE BORDER=0 CELLPADDING=0
<TD BGCOLOR=33CCCC WIDTH=0>
<FONT COLOR=YELLOW><H5><CENTER>1. Yes.<P>2. That would be fine.<P>3.No. However if you meant "refrigerant"
you should have it evacuated by a shop.</H5><H3><P>
<CENTER>REFUSE
TO
LOSE</TD>
</CENTER></H3>
Old Feb 6, 2006 | 06:08 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Why do you always post in that annoying light blue box?
Old Feb 6, 2006 | 06:12 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
why not just take the canister off too? i did it with no problem and no bad side effects
Old Feb 6, 2006 | 06:46 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
So what's the "big" difference between doing the entire swap with a non ac box compared to keeping the stock box and just plugging it ?
Astetics ? 1 ounce or two of weight saving ? Smaller box ?
Old Feb 8, 2006 | 05:00 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
the a/c delete box is extremely tiny and you can reach the # 8 plug from the top.
Old Feb 8, 2006 | 07:58 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Also the AC delete boxes are metal, while the AC boxes are plastic. I noticed when I pulled my AC box I actually had scorched/melted spot on mine from being so close to my Edelbrock TES Headers.
Old Feb 8, 2006 | 09:01 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
whoa so they REALLY make for tons of room huh
Old Feb 13, 2006 | 01:07 AM
weberflorida's Avatar
Car: 1991 Camaro Z28
Where do you get them from?
BIll
Old Feb 14, 2006 | 08:51 AM
Engine: 383 SBC
No company is currently making them. GM has also discontinued them. Dave gets them from time to time and posts them for sale on his website (should beable to find him using the search).
I bought mine from him. You're going to have to find a place to pick it up 2nd hand (Junk Yard, Classifieds, Ebay). Just make sure you grab the blower motor too because your stock AC one will not fit in the new box without a custom made spacer.
Basically any 3rd gen firebird camaro without AC should have the right style box.
Old Feb 14, 2006 | 09:44 AM
Sucks that they keep discontinuing stuff. I need a factory exhaust hanger but guess what... It was discontinued. LOL!! So I am going to go over to Vorgath's house and take it off his car at night time.
Bill
Old Feb 14, 2006 | 05:38 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
HAHAHAHA !!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
