fan won't come on
Old Feb 16, 2006 | 10:12 PM
intruder's Avatar
fan won't come on
i have a 89 ta with dual fans, they were working fine and all at once it quit, i took the wire off the switch under the pass side manifold and grounded it and all i get is a click from the relay, where else should i look the fan does work i hot wired it so it's not the fan.. any help would great.
Old Feb 16, 2006 | 10:16 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Sounds like a bad relay?
Old Feb 16, 2006 | 10:17 PM
intruder's Avatar
how will a t stat cause the fan not to run
Old Feb 16, 2006 | 10:22 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
If the t-stat is stuck on open or closed it will not operate properly
Old Feb 16, 2006 | 11:25 PM
intruder's Avatar
i changed the relay and it still didn't work, i swapped thr fuel pump relay and fan relay around fuel pump still worked but fan didn't
Old Feb 16, 2006 | 11:31 PM
intruder's Avatar
is there another switch that controls the fan
Old Feb 16, 2006 | 11:39 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
1ST-- check this like stated before
if this is ok then recheck the relay to make sure that it operates properly--possibly a crossed wire. i would also recheck the wiring for resistance and that the grounds are good--remember that wire can corod inside the jacket
let us know what you find
later
and
GB
rick
junior419
Apr 7, 2025 11:35 AM
Bubbajones_ya
Jul 6, 2024 08:32 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
gta892000
Sep 16, 2015 12:37 AM
