Heater Core = Easy Fix
Old Feb 22, 2006 | 08:53 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
Swapped heater cores on my 89 camaro today in under an hour. Everyone tells me you have to pull the dahboard to do it... thats BS.
disconnect hoses to heater core under hood
Pull dash pad off
Remove Passenger speaker bracket (leaving speaker attached)
unplug and remove ECM
remove 4 7mm screws around heater box cover
remove 4 7mm screws holding heater core assembly to the box
remove heater core assembly from vehicle
remove 3 7mm bolts holdgin heater core retaining brackets
install new heater core assembly into vehicle
assemble in reverse order.
It's just that easy....
-Jim
Old Feb 23, 2006 | 10:58 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
i didnt even unplug my ECU or remove it when i changed out my heater core in my 83
Old Feb 23, 2006 | 10:59 PM
llvll4l2c91350's Avatar
yea on these cars its easy.
same year S10 trucks on the other hand...
Old Feb 28, 2006 | 10:07 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I don't even remove the dashpad or speaker - just reach up in there and get that last screw by feel - but I do remove the ECM to get the extra room for my hand and rachet.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
89 formula TPI
Sep 8, 2015 08:00 PM
