removing HVAC system, advice needed, 87 iroc tpi
Old Mar 1, 2006 | 09:47 AM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
next week (my spring break) i am going to be getting shop time at my mechanics shop.. he's guna let me use his lift/tools/ etc to pull the HVAC system out of the IROC
I'm guna get rid of the AC compressor, hoses, freon tank, and the heater core, along with extra coolant lines, wires, and on and on...
--MY questions are as follows?
- Anyone who has done this before,how difficult is it? How long should it take? Is there anything i should look out for? Are there any steps or rules to follow when removing an A?C and heater unit? (I dont need heat, cars a spring-summer car, and i've used the A/C/ once .. 5 years ago).... therefore I want to get rid of all of it, mostly because I am going to be cleaning up and painting the engine bay of the car this summer, ...
-Dont i have to release the pressure on the freon tank, and depressurize the system.. also, what type of holes will be left int he firewall, and any recomendations to cover them, fill them, or whatever..
-ive read lots of posts on here about the topic, just wondering if anyone has anything advice for an 1987 IROC TPI
Any help is appreciated. -Dave
Old Mar 2, 2006 | 10:05 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
alright, well ive done a bunch more research.. onlya few remaining questions...
will the wirees i remove throw the SES code?
what wires should or should i NOT remove?
-any advice as to waht type of plate, or whatever to put in place of the rectangle hole that will be left above the radio?
will the ECM suffer at all? need to be reprogrammed (prom) or anything?
Old Mar 2, 2006 | 10:32 PM
llvll4l2c91350's Avatar
no need to reprogram anything or be concerned with an SES light coming on. not sure on what wires u can remove. i left all mine alone when i removed my A/C stuff. i'd just leave the wires there.
Old Mar 13, 2006 | 03:27 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
awesome, so over my spring break, i tackled this project,
-i did most of it at night time after i worked construction in the daytime, so it took me a while, but it was better to be safe than in a rush
got the condensor, compressor, lines, evaporator, heater core, under dash plumbing temp control panel, all that out,, its all gone and in a few boxes.. weighs out to be about 62 lbs !
i also took a lot of time and moved around some of the non-sense wiring and hoses to cluttered up the engine bay.. made a batery tray, capped off some emissions tubes, degreased the engine bay, replaced the thermostat, and a buncha other things.. i took some pictures too, but havent uploaded them from my camera yet...
throughout the course of the project i documented 97% of it, almost everything, however one thing which i did not write, which i WISH i had.. is which bundle of wires i pulled out of each of the 3 relays.
----im talking abotu teh 3 relays in the cluster right by the master cyl.... one if for fuel pump, one for MAF, and one for A/C (i think, or Burn offf)
----and when i put them back on, (after hiding the wires better than the factory did) i wasnt sure between the two... I know i got the fuel pump one right, because, well my fuel pump runs,a nd i drove th car all day saturday... however, im Not sure which relay wires int he cluster i removed from the other 2 relays, bot plastic pieces fit in each of the 2 relay female ends..
sometimes when i plug one in it will make a loud BUZZZING sound , so i undo it and think its wrong, however i unplug it, and the code will light up.. CODE 34 for MAF, now i have checked the code and know about it in my 1987 Shop manual, yet everytime i think i reset it, it'll go off.. code 12, then 34,, ( i think 12 is the standard one tho...right????)
---so basuically everythign went really smooth and im really happy with having no HVAC system, (ive got tons mroe work to do to clean, polish, and arrange the engine bay, as well as have a brushed aluminum plate made up... yet, i just need to figure out this one code.. code 34, M.A.F.
anyone have any ideas on what couldbe setting it off.. (and ive disconnected the battery every time, to reset the code, but it still comes up... i think ihave the relays switched...
** and if anyone with an 87 IROC can tell me the color wires that go into the male relay for each realy, that wouldbe incredible, i definately could figure it out then
do u think i burned out the relay at all by plugging the wrong male relay in ?? is that possible???
Dave
(ill post pictures in a day or so)
Old Mar 22, 2006 | 09:33 AM
IROCZman15's Avatar
Car: 1987 IROC-Z
it took me a while to sit down and upload these pics, but here are some of the photos i took during the project
link to the page on my website:
http://www.freewebs.com/iroczman15/workdone2006.htm
-and as for the code 34, i think i am just going to get all 3 new relays from a chevy dealer if they make them, and fix the issue that way.. but i did find the wiring diagram, so we'll see
Wade787b
Sep 29, 2015 01:15 PM
NBrehm
Aug 25, 2015 11:49 PM
mustangman65_79
Aug 11, 2015 03:17 PM
3rdgenparts
Aug 8, 2015 07:09 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
