Heater Control Valve - Delete?
Old Mar 13, 2006 | 11:08 PM
FightinAggie09's Avatar
Car: 88 z28 Camaro
Engine: 350 tpi
I was thinkin today with my engine and wire harness out if getting rid of the heater control valve and just replacing it with a PVC T would affect anything. I've kind of had enough with routing vacume lines so I really don't want to have to worry about the one for the heater control valve. So if I were to do this wouldn't coolant just constantly be ran to the heater core? As long as the door for the heater core is closed it shouldn't affect the temprature inside of the car I think. I figured I'd get someone's opinion before I did this just so I don't miss anything.
Old Mar 14, 2006 | 06:14 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
i have eliminated the heater control valve on my v6 but thats just because the vacume line going to it was dead. I got some pipe from homedepot. Made a half *** valve looking thing and vuala heat. The only bad thing about coolant constantly going to the heater core is that the inside of the car gets real warm even if you have the heat off.
Old Mar 14, 2006 | 06:41 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Teeing it would cut the amount of fluid to the heater core by opening up an alternate route (back to the engine). The control valve was either 100% to the heater core or 100% back to the engine.
Old Mar 15, 2006 | 06:40 AM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
I did away with mine on my 305TPI last year. Also got rid of the hoses going to the throttle body. I cut the metal hose off just before the "T" that went to the heater control valve, and replaced it with heater hose. Looks much better and cleaner.
Old Mar 19, 2006 | 07:58 PM
Car: 88 z28 Camaro
Engine: 350 tpi
I might try doing that then. Although now I'm back up at A&M so I can't work on the car any. Thanks for all the feed back.
The_Phoenix
Feb 4, 2016 07:10 AM
lakeffect2
Aug 23, 2015 08:44 AM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
