Dual fan purpose??
Old Mar 30, 2006 | 11:05 AM
REDRIGHT9's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: AUTO
Dual fan purpose??
I have a '91 RS with a single fan. I live in a hot climate area, wanting/going to convert to dual fans. My car does not have air conditioning though.... My question is, what was the purpose for installing dual fans, is it just for a/c cars??? or for the cars that had a 350 or options??? Also, I really dont want to wire in a toggle switch to the second fan and manually turn it on...It looks like then from what I am seeing is that my only other option is to wire it to come on with the first fan...Is this correct?? thanks for the help..
Old Mar 30, 2006 | 11:48 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
If you want to convert, it's honestly just easier to hotwire them to a switch. You could wire them to the temperature sensor if you wanted to spend some time doing it.
Old Mar 30, 2006 | 07:56 PM
MdFormula350's Avatar
yeah usually the dual fans are needed for the a/c people.
what temps are you running now?
a single fan should get stuff done, i use a 180 t-stat and when at the track turn on my second fan to keep cool. my drivers fan hardly ever gets used now since i never get up to 227 or around that.
Old Mar 31, 2006 | 10:38 AM
REDRIGHT9's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: AUTO
I have a 185 t/stat in the car. Seems to run cool when moving, but when the temp gets hot or in traffic, it doesnt get below half gauge....And the one fan never seems to turn off. I was just trying to get a more efficient fan set up.. the single fan just looks cheesy and barely effective.
Old Mar 31, 2006 | 03:45 PM
memyselfandkitt's Avatar
Car: 1982 Pontiac Firebird
Engine: 305 5 ltr V8
Transmission: Manual
I installed a duel fan setup on my 82 firebird and it definately helps to keep it cooler in traffic,If your having cooling problems run a lower temp thermostat maybe a 160 degree unit, also check radiator temp make sure its got good flow and not blocked
Old Mar 31, 2006 | 03:48 PM
REDRIGHT9's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: AUTO
I planned on getting a better radiator anyway...The one in the car looks rediculously small for the car.. and when it gets 110+ outside, it just doesn't cut it.
Bubbajones_ya
Jul 6, 2024 08:32 PM
z28joe2
Sep 28, 2015 05:54 PM
Kylej68
Exterior Parts Wanted
Sep 28, 2015 10:00 AM
ivan1137
Sep 23, 2015 09:08 AM
scotrans am
Sep 5, 2015 04:26 AM
