Electric fan not working properly
Old Apr 7, 2006 | 07:46 PM
golden's Avatar
Car: '89 Firebird
Engine: 305 TBI (LO3)
Axle/Gears: 10 bolts 2.73
I was coming from school the other week and , at some time I started smelling that something was burning in the car . 10 seconds later , white smoke was coming out of the hood . I parked the car in a parking lot and then opened the hood thinking it probably was the radiator hose . Actually the smoke was coming from my electric fan motor . I tried to make the fan turn with my hand but it was jammed . The day after , I changed the motor but the fan didn't start at 90 degree . I changed the relay and it still doesn't work . Could it be the Fan Switch ? (the 20 amp fuse under the dash is not burned off and when I jump the fan wire with the fusible link wire , the fan runs .)
Old Apr 7, 2006 | 08:53 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Not sure exactly how this works, but you can jump the A and B terminals on the diagnostic connector under the dash, and the fans will come on. Seems like you turn the key on first, then connect the two terminals. Check on this before you try it, been a while since I've fooled with this.
RazorN8
Jan 7, 2022 11:44 AM
Vintageracer
Jan 10, 2020 05:33 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Leggman1
Aug 6, 2015 04:15 AM
