No heat
Old Apr 10, 2006 | 05:34 PM
Stevo's Avatar
Car: Pair of 92 Z28s
No heat
Heat blows COLD, like cold air from outside cold. All speeds work and A/C does work. Im not low on coolant, and thermostat is less then a year old. Car maintains temperature normal. Both fans work when supposed to. Ive checked the heating lines and such nothing strange about them. Anyone have any ideas?
Also this is a 1992 Z28/5.7
Thanks, Steve
Old Apr 10, 2006 | 05:38 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Thanks, Steve
Is it leaking any coolant inside, could be the heater core?
Old Apr 10, 2006 | 05:39 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
maybe the vacuum operated door that moves when you turn the lever to hot isn't working?
Old Apr 10, 2006 | 05:41 PM
Stevo's Avatar
Heater core is fine and its not leaking coolant anywere in or out of the car. Ive gone through all the different controls and all the air moves in every position. Only thing is that the air is just cold lol.
Oh sorry misread what you said about the temp lever...im gonna go drive around and see if the outdoor temp changes the air coming out. Ill try A/C and what not.
Oh wow thats really strange...just got in the car to leave...and i have heat...
Thats really wierd, it hadent been working for the past week or so. It hasent been that cold luckily so i havent needed the heat. I guess something just got stuck...but i dont know what.
I feel dumb asking about my car that just fixed itself...
Old Apr 10, 2006 | 06:15 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
GREMLINS
Old Apr 10, 2006 | 06:16 PM
Engine: 355 chevy
lol what he said.
Old Apr 10, 2006 | 08:43 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
even though you say you changed it a year ago, i would double check your t-stat. My dads van had the same problem and it was the t-stat. just my
Old Apr 10, 2006 | 11:30 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I agree on the sticking heater valve. Stuck one moment, unstuck another....
If the engine temp is normal, the thermostat is probably working fine.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
