coolent not recovering
Old Apr 13, 2006 | 06:39 PM
coincounters's Avatar
Car: 1984 z28 ho
Engine: L69
Transmission: 700-r4
i'v changed the radiator cap but the coolent will not flow back into the radiator. when i open the cap to check coolant leval i have to pull hard on the cap, it creates a large suction. you can see the radiator upper hose has collapse some until the suction is releasted. the car is not overheating. i'm out of ideas, can anyone help?
Old Apr 15, 2006 | 10:14 AM
BlackThunder's Avatar
Car: 1988 Pontiac Firebird Sport Coupe
Engine: 350TPI V8
Transmission: TH700 with o'drive,TCL, WS6
Axle/Gears: Borg Warner Posi 3.27:1 ratio
I've not owned my Firebird long enough to know anything for sure, and you can discover from my posting elsewhere in this list that I have my own problems with the cooling system, but it sounds to me like something might be blocking the pipework between the engine and the coolant recovery tank.
Does the level in the coolant recovery tank go up significantly from the Cold Full mark when the engine is hot ? It should. Does a vacuum develop in the recovery tank as well when the engine cools down ? It shouldn't.
Is the small breather hole in the recovery tank cap open ?
Old Apr 15, 2006 | 07:33 PM
Car: 1984 z28 ho
Engine: L69
i checked the vent , its ok. pulled off the tube its ok also. i cant imagine losing pressure somewhere else inside the engine faster than the coolent recovering, but i guess anything is possible.
Old Apr 17, 2006 | 10:39 PM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
If the radiator neck vent isn't plugged, it's got to be the valve in the cap. I know you said you replaced it, but check to make sure the valve isn't jammed or obstructed. It should open will very little effort.
Old Apr 19, 2006 | 03:28 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
i replaced my cap as preventitive maintenance......turned out that my replacement cap was defective!
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
86IROC112
Nov 7, 2015 06:50 AM
RedLeader289
Sep 23, 2015 06:50 AM
MORREALE5
Sep 13, 2015 09:01 PM
