NEED HELP...TEMP SENSOR!!!
Old Apr 15, 2006 | 05:35 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
ok i try and explain exactly what has been done. I bought a hypertech fan switch(on at 200 off at 185), i located the stock one just above the starter solenoid between the 2 rear plugs. changed the switch out, However, the wire that went to the stock switch did NOT look like the connector that hypertech gave me. So i just figured it was the wrong type of connector, cut the BLACK wire and spliced the 2 wires together with the NEW connector that hypertech provided. Started the car up...and now my temp guage is not reading anything and ive let the car run for about 25 mins or so and neither fans are coming on. So after that i figured because the connector was wrong that must not be the fan switch...it must be something else. So i put the stock one back in and spliced the stock connector back on it....soiderd(sp?) it up...made sure of my connections and pluged it back into the stock switch. I still have the same problem. Nothing reading on the temp guage. Now i will say this, on the stock connector there is a circle plastic peice and inside is the PIN that goes into the stock switch....but around the circle peice there is a connector that goes all the way around it which SNAPS onto the switch.....when i took the stock one out...that part fell apart in my hands...not the circular part with the pin...but the snap on part. Its in the stock switch now nice and tight......but i still have the same problem. Could i have popped a relay?.....or possibly popped the PCM???? any help owuld be great guys! Thanks
Old Apr 18, 2006 | 10:39 AM
91black5spd's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Transmission: 5 speed Manual
That is weird. I did the same thinbg when changing mine - The old plug cracked apart and I just cut the wire and spliced in the hypertech wire and now mine works fine. Maybe somehow it got shorted out while you were working onm it. Check your fuses and see it might be something simple like that.
Old Apr 18, 2006 | 05:58 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Maybe you got the knock sensor instead. There are two sensors on pass side, the knock sensor, and fan switch. They both have the same connector on them. One is in the block, one is in the head (I don't remember which is which). Did coolant spill all over you when you swapped? if not, bet you got the knock sensor instead.
Old Apr 18, 2006 | 08:11 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Transmission: th 700 r4
Axle/Gears: stock
i didnt even put my knock sensor on
Old Apr 18, 2006 | 09:47 PM
TorchRay's Avatar
Car: 89 WS6 Formula
nah i found the problem...it was the connector. I just replaced it and...bingo...my temp guage is back to normal
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
