BIT OF A PROBLEM
Car: 1982 Pontiac Trans Am (Recaro)
Engine: 5.0 v8 (305 TBI)
BIT OF A PROBLEM
Ive just fitted my new digital temp guage and works great, but ive disconected the old temp guage wire from the sensor and after running the engine for 5 min or so the "CHECK ENGINE" light apears. I did try and connect the old gauge up to the senor with the new guage but the new guage didnt like it very much. any idea how to by-pass it? tried grounding it but the light still comes on.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You've taken out the coolant temperature sensor for the ECM, not the coolant temperature sender for the gauge.
So i should connect this back, i thought it was part of the guage? if so ill pop it back on in the mornin a bit late to do it. Shall i try connecting the digital temp and the other wire again ???(i did notice when i connected the wires they were a bit lose)
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yank the sender from the driver side cylinder head. Put whatever one you removed back where it was (sounds like you yanked the CTS from the intake).
db057
Aug 11, 2015 10:11 PM
