H20 Neck w/ Temp Sensor Bung
Old May 9, 2006 | 06:31 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
I am looking for a water neck that has a bung for an aftermarket temp sensor. I know I have seen a picture of one somewhere.
Did any other GM car have a sensor in the neck?
Old May 9, 2006 | 06:51 PM
iroctj's Avatar
Car: 86 IROC-Z
Engine: 385 TPI
Transmission: 700-R4
Axle/Gears: 9Bolt 345'S
Welcome to Year One has what you need also try jegs and summit
Old May 9, 2006 | 07:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Pretty much every other GM vehicle had a sensor in the water neck, beginning in the emissions era.
Old May 9, 2006 | 10:06 PM
Car: 91RS_92Z28
Engine: 5.0_5.7
WHich model will fit my lo3?
Old May 9, 2006 | 10:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Just about any of them.
Old May 9, 2006 | 10:16 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Depending on what you go with, one thing to keep in mind, some aftermarket senders are 1/8" NPT (I just drilled and tapped a new hole into mine instead of dinking around with various reducers).
Old May 9, 2006 | 11:20 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I have one from Carquest. Just check the picture!
Attached Thumbnails H20 Neck w/ Temp Sensor Bung-proamfullengine.jpg
johns84bird
Aftermarket Product Review
30
Apr 18, 2005 12:48 AM
dans82bird
Aug 18, 2002 03:18 PM
85SportCoupeto89RS
May 19, 2002 12:03 PM
Alan84TA
Mar 1, 2001 09:25 PM
