Air dam on 85 Transam
Old May 28, 2006 | 06:00 AM
blackknight2010's Avatar
Car: 85 Transam
Engine: 305v8 carburetted
The air dam on my 85 Transam has been missing since I bought the car. Not had any cooling issues, but as am restoring the car, would like to fit one. Have seen one on Ebay for the 90-92 models. Would this fit to my 85?
Thanks guys.
Old May 28, 2006 | 08:50 AM
85T/A's Avatar
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
Air Damper
Hey Guy,
I dont know weather they will fit or not but i am missing my original one too... i took a piece of easy to bend metal cut it to size drilled some holes and bolted it into place then i bent it to shape..... now without that on i had cooling issues because i dont exactly like driving the speed limit (50 where i am at) but after i put it on it helped me out in that area greatly.. i know you said you werent having any cooling issues but if your ever in need of a quik fix its the easiest way to go
Old Jun 3, 2006 | 08:10 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Classic industries sells this part. I believe Year One does also.
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
tommy z-28
Oct 6, 2015 10:58 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
