No fan switch
Old May 29, 2006 | 02:27 PM
ace16a's Avatar
Car: 1985 Z28 Camaro
Engine: 5.0 TPI
Transmission: 700R-4
Axle/Gears: Posi Richmond 3.73
No fan switch
I have a 1985 Z28 Camaro with a TPI. My fan quit working recently so I started replacing stuff. I replaced the fan relay and fan motor. Then I went to replace the fan switch and just saw a plug where the switch normally is. If there is no switch, then what controls when the fan comes on and off?
Old May 29, 2006 | 02:43 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Fan switch
Hi,
Not sure on the earlier 3rds but if you have the dual
fans ECM controls the primary fan and the head switch
controls the secondary.
Later
jaykar
Old May 30, 2006 | 08:14 AM
ace16a's Avatar
Engine: 5.0 TPI
My car is a single fan setup. I did figure out why the fan isn't coming on. The plug that goes into the fan relay is shorting out. If I hold it in the relay, the fan works as it should, but if I let go, the fan quits working.
New question. Is there any advantage to using the fan switch in the head or is the computer controlled method just as good? If I were to use the switch in the head, how do I go about wiring it so that the computer doesn't try to control the fan as well?
Old May 30, 2006 | 03:21 PM
jaykar's Avatar
Fan Switch
Hi,
Since your running a single fan setup you will have to
change the setting on, fan on, fan off temp control with
chip work.
I suppose if you wanted to change over to dual fans
like the later cars you could always run a secondary
temp switch of your choosing(Temp Wise) and set the primary fan with the chip.
All that turns on the secondary fan on is hot to ground
at a certain value.
HTH
Later
jaykar
Old Jun 1, 2006 | 12:51 PM
schnekkie's Avatar
Car: 85 Z28
My 1985 Z-28 (single electric fan) also had a plug in the head where the fan switch would have gone. The fan worked normally the entire 4 yrs i had the car. My brothers 1985 Z also has the same setup. Neither my car nor his had the wiring which would have connected to the fan switch so I assume the ECM is controlling the fan on 1985 TPI camaros (using the temp sensor in the front of the intake under the throttle body) No wiring diagram I've seen shows this though.
BTW i live in NW iowa and sold my 85 Z in 2000, any chance its the same car?
Old Jun 1, 2006 | 03:43 PM
ace16a's Avatar
Engine: 5.0 TPI
From what I've read, the 85 TPI cars use the temp sensor in the front of the intake manifold to monitor temp and the ecu commands the fan on and off. My 89 T/A had the switch between the 6 and 8 cylinders.
Today I was driving around and my car started overheating again. I checked the relay and found that the relay isn't getting a command to turn the fan on. I've replaced the fan relay, coolant temp sensor, gauge sensor, and fan motor. I also recently replaced the pcm with one from a 85 T/A TPI because my original pcm wasn't commanding the torque converter.
I'm originally from Inwood, IA. I bought my car in Feb of 2000 from a guy from Inwood also. I don't remember the last name but his first name was Bruce.
Old Jun 4, 2006 | 02:22 PM
schnekkie's Avatar
Car: 85 Z28
hmm, i know that guy. PM sent
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
