Best Looking Water Thermo Neck....
Old May 29, 2006 | 10:50 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
I'm about ready to start going through my cooling system. When I change out the thermostat, I'll want to replace the housing with something much sharper looking than factory.
There are so many different ones available: short, tall, adjustable, etc. Does anyone have a recommendation of what fits nicely and looks great???
Also, I'm thinking of replacing the radiator hoses as part of the cooling system 'tune-up'. I'd like to do one of the color keyed hoses- are there better brands than others for these type?? (I'm planning on going blue)
Nitro
Old May 30, 2006 | 04:12 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Why not just fully polish your original one? Once you start polishing things, you might not want to stop...
Old May 30, 2006 | 02:01 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If you want nice, billet aluminum looks good.
Old May 30, 2006 | 02:30 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Get one with the o-ring instead of a gasket.
Old May 30, 2006 | 09:21 PM
neagan's Avatar
Best looking Water Neck/O ring.style...
I do want an O' ring style, as I'm going to be constantly in the top end of the engine as I slowly modify the performance abilities and the O-ring seems to be better about removing and reinstalling it a handful of times. Would there likely be any clearance issues if I use a taller billet item??? The IROC engine compartment is still not imprinted on my brain and is parked this week at my In-Laws house for a few days. Nitro
Old May 30, 2006 | 11:00 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i like the mr. gasket ones you can buy at most parts stores. typically under $15 and they're chrome. they look good for a year or 3 then you replace them with new ones.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
jrdturbo
Mar 31, 2016 02:58 PM
jaridjohn
Oct 5, 2015 07:01 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
