Problems cooling a new built 383 stroker
Old May 30, 2006 | 01:14 PM
TransAmGTA88's Avatar
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
I just got a 383 stroker put together and running im sure i have plenty of coolant in it. I was wondering if i need to go to a 4 core radiator? i have both the dual fans hot wired to switch and operating when car is running. I realize that new motors runs a lil bit hot at first. Any suggestions?
Old May 30, 2006 | 01:33 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Make sure the timing and fuel mixture is at least close.
The cooling system could be air bound, make sure to bleed it all out.
Does it overheat sitting still or when you're going down the road?
Old May 30, 2006 | 01:58 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
That and factory fans are kind of crappy to begin with...
But you won't need a 4 core.
Old May 30, 2006 | 02:08 PM
Car: 88 GTA, 74 T/A
Everytime ive checked the coolant level it has been full. The timing is set to 35 or 36 degrees total timing. It gets up to 220 pretty quick within 5 to 10 mins.
Old May 30, 2006 | 03:21 PM
Dialed_In's Avatar
See above replies
You have a shroud around the fans?
Old May 30, 2006 | 05:21 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Initial timing, vacuum?
Upper hose getting "hard" from pressure?
Thermostat?
heater core? bypass?
Old May 31, 2006 | 07:45 AM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
like said above first check ur fuel and timing, if the initial and total timing is too far retarded it will get hot very quick.
I run a 2 core aluminum radiator, made by Wizard Radiators, and i run a 160 stat, car sits in traffic at 170* at idle in 90 degree heat, good luck!
Old Jun 1, 2006 | 12:20 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
If your running the stock dual electric fans and a 3 row radiator you should have a problem I would say your problem is in the timing or maybe a bad thermostat. My brother has a 383 in his s10 with a stock 2 row brass radiator and two fans and the thing will never go above 210.
RazorN8
Jan 7, 2022 11:44 AM
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
Mickeyruder
Sep 2, 2015 02:45 PM
sreZ28
Aug 14, 2015 07:48 PM
