dart heads temp sensors don't fit hmmmm what to do
Old May 31, 2006 | 09:46 AM
project86ta's Avatar
Car: 86 TA
Engine: 305 carb
Transmission: 700 R4
Axle/Gears: Not Sure
Hey guys I'm putting in a 350 and the fan switch and temp gauge sensor will not thread in to the dart heads. Is there an aftermarket sensor I can use and just wire it in to the facotry gauge ??
Old May 31, 2006 | 09:52 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Are you staying carbed? Just put it in the intake.
Old May 31, 2006 | 10:15 AM
Car: 86 TA
Engine: 305 carb
yeah It's going to be carbed...... just get a reducer and drop it in the intake? I was trying to keep wiring away from the top of the engine.
Old May 31, 2006 | 10:32 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Depends on what kind of intake you have. Do you have any holes you could use in the back beside the dist? That would help hide the wiring.
Old May 31, 2006 | 10:48 AM
Car: 86 TA
Engine: 305 carb
It's an edl-2101-1 edelbrock performer
Old May 31, 2006 | 10:52 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
I just used a reducer and still used the head location.
Old May 31, 2006 | 11:17 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I am moving mine to get them away from the headers.
Old May 31, 2006 | 11:29 AM
Car: 86 TA
Engine: 305 carb
My headers are getting ceramic coated so I don't think it would be an issue
Old May 31, 2006 | 12:25 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Sounds like the reducer would be the best idea.
Old May 31, 2006 | 01:30 PM
Car: 86 TA
Engine: 305 carb
Ok I'll go with the reducers....... Thanks
Old May 31, 2006 | 01:45 PM
tough87's Avatar
Car: 87 camaro sport coupe
Engine: home build 350
Transmission: BW T-5
Axle/Gears: still stock
I have cast iron Dart II Sportman heads on my engine. I am using off the shelf temp sensor and fan switch from Autozone or where ever. That was almost 9 years ago, so my memory is not completely clear, and hole size on the heads may have changed since then. You might try ones from a 70's model chevy. I say this because my other car at the time was a 73 chevelle and my dad had a 78 corvette, and I think the sensors from those matched up with the dart heads. A good strategy: go to an auto parts store, not Autozone or Pep Boys, but a store with a bunch of older guys working in it. They should be able to help and willing to do so. Or better yet, call Dart (or World Products or whoever they are these days) and tell them which product you have and what car it's going into.
The fan switch is no longer a concern for me since I've switch to a belt driven fan. Simple, functional, and dead reliable.
Old May 31, 2006 | 04:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Older stock heads had a 1/2 NPT hole. Newer heads have a 3/8 NPT hole. Most aftermarket heads use the larger size because it's easier to put a smaller fitting into a bigger hole with a pipe bushing than it is to put a bigger sensor into a smaller hole.
Old May 31, 2006 | 09:22 PM
tough87's Avatar
I was remembering something allong those lines, so try second gen components.
Old May 31, 2006 | 09:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, don't try second gen components. Go get a pipe bushing.
Old Jun 1, 2006 | 08:18 AM
Car: 86 TA
Engine: 305 carb
the plugs were painted over and the square in it wasn't a 3/8's rachet so I just mached the sensor up to the plug but the diameter on the threads looked way to large on the sensor. Well when I got home last night I threw a pair of vice grips on it and when it started turning the paint gave way and well to make a long story short they're the right size.......
Old Jun 1, 2006 | 07:59 PM
tough87's Avatar
Depends: for me second gen parts worked fine because all my engine related stuff (ignition, fuel, and such things) are second gen technology. You're right if someone is running EFI and such things.
Old Jun 1, 2006 | 09:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I can't imagine a single component that could possibly screw into a coolant port on the head that I'd want to find a second gen replacement part for.
Old Apr 29, 2009 | 03:13 PM
87350IROC's Avatar
Car: 87' IROC
Re: dart heads temp sensors don't fit hmmmm what to do
Back from the dead!
I have the same issue. However when I use a pipe bushing the fan switch sticks out too far and hits the dipstick. So I'll looking for go for something that is a direct fit. Anyone have an idea of what part I should look for. Stock second gen stuff? Is there one that will turn on lower than stock?
Thanks,
John
Old Apr 29, 2009 | 03:30 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I am using Dart Iron Eagle heads and have used both the Hypertech & Jet fan switches. They both fit fine and are available to turn on the fan at a lower temperature.
Old Apr 29, 2009 | 03:44 PM
87350IROC's Avatar
Car: 87' IROC
I am not using Dart heads. I am using TFS heads. Also I bet it has a lot to do with how the dipsticks mounts to the headers. My headers are SLP. So when I use the hypertech I do have clearance problems.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
NinjaNife
Aug 23, 2015 11:49 AM
timonator
Aug 11, 2015 09:56 PM
