Took off the plastic cover, found a little surprise in my behind my bumper
Old Jun 6, 2006 | 11:45 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Any thoughts on this? Must have been installed by a previous owner, I never knew it was there and I'm sure if the seller knew he would have mentioned it when I bought the car. Should I move it? Can I disconnect those hose lines to clean it/move it without spilling fluid everywhere? Should I just leave it? It doesnt seem like it has any ability to correctly function wedged in there like that.
Transmission Cooler Pic #1
Transmission Cooler Pic #2
Old Jun 6, 2006 | 12:17 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
You will lose some fluid. Put a drain pan under the car and remove it.
Also mount it in a better place
Old Jun 6, 2006 | 03:45 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
It looks like the hoses may be leaking on you now.I agree on cleaning/relocating it for better airflow.At least it's a plate type cooler that's better at heat dispersal.
Old Jun 7, 2006 | 10:52 PM
OSS's Avatar
OSS
Car: 1985 Trans-Am
Engine: 305 LG4 4bbl
Axle/Gears: 3.27 Limited Slip
Thats pretty cool, (pun intended :P) I'm kinda interested in an oil cooler, where would an ideal spot be for such a thing?
-OSS
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Mar 18, 2019 08:29 PM
Wylecoyote08
Aug 22, 2015 01:58 AM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
